7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible), 99 guests, and 3 robots.
Topics128,136
Posts1,056,430
Members48,441
#1428689 10/31/2021 11:31 PM
Finally got my 46 pickup running after replacing 4 push rods and found that I have a cracked block. Any suggestions on a fix.
Thank you.
Where is the crack? If the 46 is running the original cooling system, it will have a "zero pressure" radiator. That means a crack repair shouldn't have to seal any pressure. I'd suggest an aggressive cleanup of the block surface such s sandblasting or bead blasting, drilling a small hole at both ends of the crack, grinding a shallow "V" and using Marine-Tex to cover it. To give the patch the proper "cast iron" surface texture, press a piece of 40 grit sandpaper over the patch as it cures.
' Offline
How deep should you drill the holes?
' Offline
And what diameter?
Find the ends of the crack and drill a 1/8" or smaller hole all the way through to prevent the crack from continuing to spread. We also used to use overlapping threaded tapered cast iron plugs for crack repair, a process called "sewing". The plugs and the tapered taps for installing them are available on Ebay.
One done with Marine Tex as Jerry suggested. Shows crack that was fixed 20 years ago and no issues even though it runs through freeze plug holes. Sand blasted, roughed up with 24 grit disc and crack "V" grooved about 1/16 deep. Use Marine Tex as it was designed for liquid rather than other epoxies like JB Weld. Sorry no finished pics. Used rubber expandable freeze plugs.
[img]https://i.postimg.cc/1f8zZyQ2/40-Pontiac-engineand-trans-002.jpg[/img]
Evan
