| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 34 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 34 | Have a 46 1/2 ton and have the chassis numbers squared away but now comes the engine numbers. Best I can read,with a magnifying glass is 3B OR BCDA 465XXX. SEARCHED ALL THE INFORMATION I COULD FIND BUT NO REFERENCE TO THESE. I need to replace soon push rods. The ones I got are thicker then the ones I have but the length. Any help would be appreciated. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Did you flip the prefix letters...BCDA? BDCA is a 1946 1/2 ton truck engine built in the Flint engine plant with RPO-227 (HD Clutch for HD 3 & 4-speed transmissions). I don't know what 3B OR is??? Post a picture... Mike B  | | | | | Joined: Sep 2021 Posts: 34 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 34 | Thank you for the response. It is BDCA. The push rods are about 12" long x .250 wide. The replacements I got are the correct length but are about .315 wide. Checked a couple of places and all they have are the wider ones. Will they work? | | |
