4 members (Hotrod Lincoln, dt235sd, 55shaker, Danielbolt), 91 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
Hey all,
So I have a 1953 Chevy 3600 3/4 ton and have been looking into IFS kits and ideas. I heard a rumor that from the back of the cab forward the frame is the same between a 3100 and a 3600 but the rear frame of the 3100 gets wider were the 3600 stays straight. with that being said, will the 3100 kits fit the 3600 same same?
Sir Searchalot
Sir Searchalot
Best to ask the people who sell them.
I have a CPP crossmember welded to my 54 3600. I had to trim a little more of the lower frame flange than I'd like. I don't know if that's the difference between the 1/2 and 3/4 ton or if it's normal. It fits well though.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
any one know if the 3600 front frame is the same as the 3100 front frame? if so how much of it is the same?
Take a look at the FAM, Section 2 Sheet 2.00 (3100) and Section 2, Sheet 2.01 (3600)
Those have dimensions of the respective frames. The look very similar, but I didn't check all the dimensions.
The 1950 Vehicle Information kit says the frame thickness is 9/64 inch on 3100 and 3/16 inch on 3600.
AD Addict & Tinkerer
I also compared the measurements in the area that the IFS would sit and they are exactly the same. I don’t know why Whitedog had to cut the bottom of the frame. Maybe it was for the tie rods.
Whitedog, what was the issue?
Phil
Project Journals
Stovebolt Gallery Forum
Curmudgeon
Curmudgeon
Originally Posted by buoymaker
That part also tells that there's a difference:
3104 Frame 5-3/4 x 2-1/4 x 9/64, 2.46 cu in Section Modulus (a measure of stiffness)
3604 Frame 5-27/32 x 2-1/4 x 3/16, 3.25 cu in section modulus
So the 3600 frame is a touch deeper as well as a bit thicker, which makes it stiffer. If other critical dimensions are the same, that depth dimension difference (3/32") wouldn't make that much difference in mounting an IFS kit. I would think it would increase the ride height by that miniscule amount.
The only problem I had was with the lower lip of the frame. The boxing plate wouldn't sit plumb. A little work with the cutoff wheel, problem solved.
Everything else fit just fine.
"The Fake Truck"
Even the 3100 frame has a droop to the lower flange of the frame in the area of the front axle, so that's probably a common issue.
Thanks for all the replies, I think I have a lot better Idea of what I will be looking for now.
