2 members (Otto Skorzeny, Wally / Montana), 326 guests, and 5 robots.
Topics128,162
Posts1,057,059
Members48,463
#1398341 02/22/2021 2:32 AM
I brought this gem home today. the intention is to replace my jeep.
Issues, the drivers (electric) window doesn't work, the rear (electric) window doesn't work, There is no oil pressure gauge, Mrs. Rod is mad at me, it is rusty.
Another quality post.
Real Trucks Rattle
Rusty Rod #1398343 02/22/2021 2:47 AM
Leo Offline
Moderator
Moderator
Nice one, what are you working on first?
Rusty Rod #1398358 02/22/2021 5:42 AM
Leo, Wife is mad because I have too many vics. AND most of them have "issues". She demanded that I fix the oil leak on my 2003 Jeff Gordon Monte Carlo first.
I'll be nickel & diming the Blazer to get it road worthy (and pass a smog test). While i'm putting the Suburban back together.
Real Trucks Rattle
Rusty Rod #1398444 02/23/2021 1:34 AM
Not sure about Colorado, but Pa doesn't require any inspection or smog test on anything with an Antique registration. Only requirement is age. 25 years old or older. Might be something to look into? ohwell
Rusty Rod #1401173 03/13/2021 3:49 AM
Glenn's, Colorado requires a smog test back to a certain year before they are exempt. After a certain year, they require a smog test annually. If I put collector plates on it, then it gets smogged every 5 years.
This peach needs to run much better before I try to smog it. I've already replaced about 12 feet of vacuum and fuel lines. All the coolant hoses are next.
Real Trucks Rattle
Rusty Rod #1401212 03/13/2021 2:54 PM
Hmmm. Interesting. I wont be moving there anytime soon. Lol.
Rusty Rod #1402351 03/21/2021 3:10 PM
Interesting, a week or so after I acquired the 67 Suburban, it snowed. A week or two after the big red blazer (I didn't name it) appears in my driveway, it snowed. The 4x4 works though, even with street tires on it.
BRB slams into reverse and drive, even when the idle is normal. I heard on the internet that bad mounts will cause that?
Real Trucks Rattle
Rusty Rod #1402445 03/22/2021 12:21 AM
bad motor/trans mounts could cause that, also may be that the idle is too high. It can be idle smooth but still high if the O2 sensors or mass air flow are not reading properly. somtimes just driving a bit can help if the stuff is just dusty/dirty.
EDIT: when the mounts dry up there will be play in bolts allowing the motor to rock side to side when you shift. (I don't recommend it but I have just tightened the bolts down to buy some time and reduce stress on the mount themselves but it can make the rubber decide to quit out entirely)
62' GMC Fleetside 3/4 ton 235 4-speed.
Time makes fools of us all.
Rusty Rod #1402446 03/22/2021 12:38 AM
Mounts are the 1st thing id check. Oped da hood. Get in da drivers seat. Do your best to see whats going on under da hood. Put it in gear. Movement? Put it in reverse. Movement? Brake torque it when in either gear. You will see whats up that way if its a mount issue. 2nd thing, could be a ton of stuff. Carrier bearing if applicable. U joints. Rear end slop. Check mounts 1st. Go from there. Keep posting.
Rusty Rod #1402472 03/22/2021 2:54 AM
I've got the tranny mounts on order. the drive shafts feel tight.
It does not slam every time either, which is strange.
Real Trucks Rattle
Rusty Rod #1402509 03/22/2021 2:39 PM
One other thing. Might be a longshot tho. Make sure you hold firm on the brake pedal and make sure the rear brakes are adjusted up. They might not be holding the rear axles enough. Kinda like putting it in gear wothout applying brakes at at all. Idle speed of the motor is a factor also. Just food for thought..... ohwell
9
9 Offline
Glenn im in CO Spgs and no smog test here!
Karl j Townsend
Rusty Rod #1422869 09/03/2021 9:26 PM
The Tranny reverted to all Neutrals! I just spent 4 hours wrangling the old one out. The "new" tranny slipped into place just like it belonged in there.
However, I did find that the exhaust system is cobbled together and leaks at nearly every seam. I'll be re-cobbling it back together so that I can see if this heap will pass the smog tests.
Real Trucks Rattle
Rusty Rod #1428242 10/28/2021 2:28 PM
I like the snow pix. I have several different vehicles that ended up coated in white that I took pictures of. Something about that snow!
BTW. My Uncle used to live in Loveland. I remember tubing down the Big Thompson as a kid with my Cousins.
Nice Blazer!
Like A Rock
Rusty Rod #1440666 02/10/2022 4:59 AM
Hey Rusty! Love the Blazer! Thats going to be alot of fun!
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
Moderated by  Leo
