| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | Hey Guys, will a 56 1/2 ton pickup grill fit in a '56 4400 series truck. They look the same but just wondering. Thanks, Steve. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if they look the same ... they are!  the bigger trucks got a totally different looking grill, which I think started w/ the 4400 and up [1½T, right?] - if you mean the openings look the same, will the other grill fit ... prolly would, just give'er a try Bill | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I'm not so sure about that. I know the AD medium-duty truck grilles look like the light-duty grilles, but are actually quite a bit larger. Measure, measure, measure. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | GMC - only 2 different grills 55-59 - the TF light truck has a grille looks like this - fits inside the hole made by the hood and fenders, leaving a raised lip around the grill - the bigger TF trucks had a completely different grill that fit in the same hole but overlaps the 'lip' around the opening Bill | | | | | Joined: Mar 2005 Posts: 25 Member | | Member Joined: Mar 2005 Posts: 25 | OK, So if they're the same openings why couldn't I put the light duty grill in the 4400 series opening? They measure pretty close. Anybody done this? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | haven't seen it done, but if it fits and you prefer the egg crate grill [I do], give it a try - you may have to drill some mount holes to suit, but that's easy - I had a 56 grill in my 57 frankentruck for a while, and it worked fine
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have seen the big truck grille bar in a '56 half-ton. | | |
