1 members (CuzzFuzz),
83
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I am looking at a 1954 1 ton. I have only seen pictures and I am in the process of scheduling a visit to view the truck. The pictures shows it has a bed not currently on the vehicle. I assume a 1 ton is a long bed? Are there any other major differences? Are body parts interchangeable? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Some 1 Tons had the extra long 9ft bed. I don't think they went to bigger front fenders and wider hood till the 1.5T. Others will know. Cab parts are same.
Evan
| | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 |
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | 1 ton front end sheet metal should be the same as well. | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Frames are different on the 1 tons 1949 gmc 1-ton | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | The running boards, aprons, front bed panel, and bedsides are all unique to the one ton. The cab and front end sheet metal are the same as 1/2 and 3/4 ton
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Don't forget bumpers and bumper brackets -- unique to 1-tons.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The 3800 radiator support is also different from the 3100 and 3600 trucks. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Whitedog -- I didn't know that. What's the difference?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The 3800 uses just a center mounting point on the lower crossmember, wheras the 3100 and 3800 uses 2 mounting points. I don't recall if the dimensions are the similar or if the 3800 is slightly taller. I've had a discussion with someone in the past, just can't remember the specifics. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Now that's an interesting factoid. I figured the 31 and 36oo's all had the same center point ... hmmmm, so front clips on the light duty AD's are *not* exactly the same. Ya just never stop learning this stuff ...
Thanks!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | The one-tons and bigger are set up that way so the frame can twist and work under the front clip without tearing the sheet metal and radiator apart. The smaller trucks had the radiator hoop cross-braced and mounted in two places to the frame. The fenders etc. bolted to the hoop. By the time I got my one-ton it had long studs and springs with washers and castle nuts holding the front end down to the frame. I don't think they came that way from the factory. I had worked on logging trucks that were set up that way to save the radiators from road shock when hauling out of the woods. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | I've been watching the progress on a buildup of a "pickup" in a nearby town that apparently began life as a 1 ton box truck similar to the ones U Haul rents. It's a mid-1980s C30 cab with a stepside pickup bed mounted to the frame with the wheel wells centered over the dual rear wheels. The builder has widened the fenders to fit over the duals, and extended the front of the bed close to 3 feet. The bed is now close to 10 feet long. Strange-looking, but sort of cool! It's in primer now, so the job obviously isn't complete. Jerry
