| | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,905 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,905 | I use Evinrude/Johnson Triple Guard grease on some outboard applications. Has anyone used it on our trucks where a high melting grease is called for such as the pilot bearing? It is very, very thick and you almost need to warm it up just to get it out of the squeeze tube. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Feb 2004 Posts: 29,838 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,838 | Most pilot bushings are "oilite" bronze, a mixture of bronze powder and graphite, and do not need to be lubed. Jerry
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Make sure you get a bronze bushing, not a cheap steel one that a magnet would stick to.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
