0 members (), 138 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
1 Offline
Hey Guys,
I’m trying to run speaker wire to the original speaker location located above the rear view mirror/above the windshield. I’m trying to run the wire using fish tape, but it seems like there is no opening at the top portion of the “A” post. Has anybody done this before? If so how do I go about doing this?
Josh
If you remove driver side kick panel and get a bright light and lookup the backside where hinges are .you will see
Where all the panels come together
dash bottom of windshield under dash ,You will see a slit insert some stiff wire it will come out by roof or right behind visor mount hole ,Also your done light takes the same route . I think that is orange wire for dome light.
!956 Gmc Napco 4x4 Factory line built .
1 Offline
I’ve already removed the kick panel & used the flat fish tape you’d use to fish wire through house walls. It seems like there is a blockage at the top of the “A” post. Maybe I need to use a smaller wire????
I had to use mechanic wire and wiggle it around .not smooth inside
When I did my dome light wire, I used a speedometer cable.
Brian
1955.2 3100 Truck
1 Offline
Did you guys have issues getting through the upper area of the A piller?
Its hard but doable I kept hitting metal ,then it just came through this was on drivers side
Try running straight wire down from the top
Passenger side never worked for me, I always used the drivers A post...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I used a drain snake used for clogged drains. The smallest diameter, and rotate it as you go. Took me almost two hours , but it did work. Good luck!
1957 3100 - 1965 C10
~Brian
