4 members (klhansen, 32Fordpuchoptop, FAST55, walter74), 95 guests, and 2 robots.
Topics128,120
Posts1,056,319
Members48,439
#1427922 10/25/2021 5:55 PM
I am looking at a 1954 1 ton. I have only seen pictures and I am in the process of scheduling a visit to view the truck. The pictures shows it has a bed not currently on the vehicle. I assume a 1 ton is a long bed? Are there any other major differences? Are body parts interchangeable?
Dave from Northern Kentucky
My 54 3100
Some 1 Tons had the extra long 9ft bed. I don't think they went to bigger front fenders and wider hood till the 1.5T. Others will know. Cab parts are same.
Evan
Curmudgeon
Curmudgeon
Big Bolt Forum Moderator
1 ton front end sheet metal should be the same as well.
Mike
Frames are different on the 1 tons
1949 gmc 1-ton
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
The running boards, aprons, front bed panel, and bedsides are all unique to the one ton. The cab and front end sheet metal are the same as 1/2 and 3/4 ton
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
24601
Don't forget bumpers and bumper brackets -- unique to 1-tons.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
The 3800 radiator support is also different from the 3100 and 3600 trucks.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
24601
Whitedog -- I didn't know that. What's the difference?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
The 3800 uses just a center mounting point on the lower crossmember, wheras the 3100 and 3800 uses 2 mounting points. I don't recall if the dimensions are the similar or if the 3800 is slightly taller. I've had a discussion with someone in the past, just can't remember the specifics.
"The Fake Truck"
24601
Now that's an interesting factoid. I figured the 31 and 36oo's all had the same center point ... hmmmm, so front clips on the light duty AD's are *not* exactly the same. Ya just never stop learning this stuff ...
Thanks!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
1 Offline
The one-tons and bigger are set up that way so the frame can twist and work under the front clip without tearing the sheet metal and radiator apart. The smaller trucks had the radiator hoop cross-braced and mounted in two places to the frame. The fenders etc. bolted to the hoop. By the time I got my one-ton it had long studs and springs with washers and castle nuts holding the front end down to the frame. I don't think they came that way from the factory. I had worked on logging trucks that were set up that way to save the radiators from road shock when hauling out of the woods.
1951 3800 1-ton
In the DITY Gallery
H Online: Content
I've been watching the progress on a buildup of a "pickup" in a nearby town that apparently began life as a 1 ton box truck similar to the ones U Haul rents. It's a mid-1980s C30 cab with a stepside pickup bed mounted to the frame with the wheel wells centered over the dual rear wheels. The builder has widened the fenders to fit over the duals, and extended the front of the bed close to 3 feet. The bed is now close to 10 feet long. Strange-looking, but sort of cool! It's in primer now, so the job obviously isn't complete.
Moderated by  Dusty53
