| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | Orig oil pan has numerous brazed repairs and some sharp dings. LMC truck had a new one for $32. So I ordered it. It looked great. I painted it and installed it with a new fangled thick blue gasket. All one piece. The instructions said not to use sealant of any kind. So against every bone in my body I installed it and torqued the bolts to spec in proper sequence. It sat for about two weeks before we were ready to put oil in it and start it. We replaced the intake manifold gaskets, timing gears and chain and gaskets, new water pump due to bypassing. all in effort to stop the leaks. After starting the oil pan now leaks between the timing cover and the front of the pan. too much so to drive it. Now I must remove the oil pan and clean it all up. Reinstall either the old pan, or the new with a mega bead of permatex sealant along the timing cover.
Anyone ever have an issue with an oil pan not shaped correctly? Seems like I can push the seal up and down with a small scribe like there is too much room between the two.
Thanks in advance
RK
1959 Apache swb stepside Atlanta Ga.
| | | | | Joined: Mar 2007 Posts: 3,386 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,386 | GM changed the oil pan front seal design on later engines. The original pan should have used a round style front seal between the pan and timing cover, the later engines use a flat type seal. You may need to change the front timing cover if the recessed area for the front seal is rounded rather than flat. I used the new style gasket your talking about on my 327 with a new oil pan and had no issue, my engine is a 68' though and I did use a very light coat of gasket maker. Hope it works out for you.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | I agree with TUTS 59, the older engines had a wide gap between the pan and timing cover, I don't know when the change occurred. I built a 383 with a mid 70's block and that pan gasket with no issue. You could use a newer pan and front cover with that gasket or original style pan and front cover with the original style front seal. Any small block Chevy pan will fit the engine as long as it clears the suspension.
| | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | Thanks guys! I havent gotten to it yet, but as soon as I remove the oil pan I will double check the lip. Cant say I noticed a difference before but I sure have a leak now. I will attempt to post a picture of the two when I get it back off.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Early replacement oil pan gasket sets had two front rubber seals, one noticeably thicker than the other to accommodate the different pan/timing cover gaps. I don't remember what year the change in deign was made. I've encountered the problem frequently when working on an older engine. Jerry
| | | | | Joined: Mar 2007 Posts: 3,386 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,386 | Just as a note not all oil pans will fit any SBC, I ran into this problem building my 327. I had intended to use the original 283 oil pan on my 68' 327, the difference was in the shape of the front. The older 283 pan had more curve and less clearance around the front main cap. I bought an oil pan for a 350 from Jeg's and had no issue with fit. I did notice that the 283 pan had a larger front seal lip than the 350, the 283 oil pan was from a 62' 283.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Aug 2019 Posts: 251 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 251 | TUTS 59, I’m curious why you didn’t just buy a 327 oil pan, since you were buying a new one anyway? 1957 Chevy 3200Daily DriverPS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights. Follow in the DITY | | | | | Joined: Mar 2007 Posts: 3,386 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,386 | Jeg's didn't really detail a difference between the oil pans for a SBC, that and I was adding a widnage tray to the bottom end. The 283 oil pan cleared the windage tray but not the front main cap, I haven't had a chance to actually look at an early 283 to see if the front main cap was shaped differently.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | Okay! I removed the new oil pan and set the old and new side by side. the old pan was about a 1/4 inch taller in the front lip. So I cleaned it all up and reinstalled it and no leaks!!!
