2 members (Otto Skorzeny, 1 invisible), 136 guests, and 1 robot.
Topics128,109
Posts1,056,266
Members48,439
My '51 - 3100 has only one spring on the driver side of the bench seat frame to seat riser. The F.A.M. Sect. 1, Sheet 2.05 shows the spring #3698449 between the seat riser and the seat frame on the driver side but does not show the passenger side. It seems to me there maybe should be a spring in the same location on the passenger side so there would be equal tension on both sides of the seat frame? There is also a hole in the seat riser on the passenger side same as the driver side to maybe accept a spring. So, my question is "should there be a spring on the passenger side or on the driver's side only"?
Charlie
'51 3100 5-Window (Restomod in progress)
O Online: Content
Both sides.
1950 Chevrolet 3100 (Ol' Roy)
Otto - thanks for replying!
Charlie
O Online: Content
You're welcome.
Moderated by  ndkid275, Phak1
