5 members (GrandpasJimmy, festerhairball, 78buckshot, 2 invisible), 152 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#1427655 10/22/2021 11:08 PM
2 Offline
i was going to have my cab sandblasted. I was going to paint the bottom of the cab and maybe inside with por 15 . but recently I read it breaks down over time from sun light should I use a different paint?
29tons #1427656 10/22/2021 11:21 PM
If you're going to sandblast, I'd just go with a good epoxy primer. If you've gotten rid of the rust (sandblasting), there's no need to go to the expense of POR15.
29tons #1427675 10/23/2021 10:25 AM
2 Offline
I am no paint expert. But I had old cars for 40 years.In the 80s I sandblasted and painted a car frame with rust mor and I still have that car the underneath looks great do they still sell this? Also i sandblasted a car and painted the frame the in the early 90s with acklic enamel I just sold that car but rust specs were starting to come through the paint so I dont want to use that. Any suggestions
29tons #1427711 10/23/2021 5:46 PM
FWIW I've had mixed results with POR15, but generally if I follow their instructions to a "T" the results have been good. No shortcuts. I always topcoat it.
Given it's highly affected by humidity, I'm speculating that results could vary a lot depending on a person's local conditions. We usually have high humidity up here.
1949 Chevrolet 3/4 Ton - Still Solid. Regular Driver
OT Vehicles:
1925 Hudson Brougham Super Six
1950 Chevrolet Styline (Parts)
1952 Canuck Pontiac Sedan Delivery (Well Underway)
1973 F250 4x4 Highboy
1977 F250 4x4 Lowboy
29tons #1427713 10/23/2021 5:57 PM
Never heard of that. I've used Rustoleum primer years ago (and still use some on small parts). It eventually gives up when up against the elements.
Epoxy primer under that acrylic enamel should do the trick. The epoxy seals the metal against the elements and the enamel protects the epoxy against degradation from sunlight, etc. That's what I used on my frame.
29tons #1427715 10/23/2021 6:42 PM
AD Addict & Tinkerer
There is a product called Rust Mort that may be what the OP is talking about. It converts the rust so it can be filled or painted.
Phil
Project Journals
Stovebolt Gallery Forum
NorthCoast3800 #1427728 10/23/2021 9:45 PM
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
Like you, I have had mixed results even with the POR15 top coat. My frame has really oxidized and even started peeling in spots. I may sand it and paint it with implement paint from Tractor Supply.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
29tons #1427774 10/24/2021 10:02 AM
2 Offline
Thanks for all the replys. and now that you have said the name rust mort sounds like what I used
29tons #1427789 10/24/2021 12:48 PM
back yard wrench turner
Late to the conversation, I recommend Master Series Silver. It will encapsulate any rust, become totally air tight.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
29tons #1427819 10/24/2021 6:06 PM
I'm with Kevin. Blast and epoxy prime paint of your choice. Work any defects after that.
29tons #1427839 10/24/2021 9:50 PM
Sir Searchalot
Sir Searchalot
I use poor rustoleum rust reformer and poor rustoleum black over that. I prefer wire wheeling a frame so as not to get media inside differential, wheel bearings, joints. bushings, etc.....and it never leaves my possession.
29tons #1427944 10/25/2021 7:49 PM
2 Offline
I have used master series on my car trailer it sits out in all types of weather and after 10 years still looks good
29tons #1427949 10/25/2021 7:59 PM
So you are familiar with Master Series. Why not use it again?
Wayne
1989 Silverado
