1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1426195 10/08/2021 12:36 AM
So, while I have the front clip off to do an engine swap, I'm looking to clean it up a bit. I noticed the fenders separating where it meets the cab.
[img]https://www.stovebolt.com/ubbthread...umber/35693/filename/20211003_113104.jpg[/img]
[img]https://www.stovebolt.com/ubbthread...umber/35694/filename/20211003_113046.jpg[/img]
What's the best way to weld this up without sacrificing too much of the paint? Just a tack at each end to keep it from growing larger? Thanks!
1948 Chevy Thriftmaster 3/4-Ton
Poncho "farming" in Ontario
Starting in the DITY
Continuing in the Project Journals
More images
There are only 10 types of people in this world, those who can read binary and those who can't.
Goach2 #1426198 10/08/2021 12:57 AM
In order to get good welds, you'll need to clean the paint off in the immediate area. I would use MIG and weld the entire length of the crack using weld dots. I'm afraid you're going to lose some paint. If you just put a tack at each end, it won't stop the crack.
Here's a couple of photos of the repair I did on one of my fenders that had similar but worse damage.
Goach2 #1426203 10/08/2021 1:20 AM
Thanks for those. So I guess I should just try and expose as little bare metal as I can to weld to then maybe see about a little color match or something?
More images
Goach2 #1426223 10/08/2021 3:20 AM
Sir Searchalot
Sir Searchalot
You might try welding from the back. Try a few spot welds to see how it does. If seems OK, do a fillet weld made of spots. Don't need to grind the weld. If it fills in nice, bondo the front side to smooth out the radius. As Kevin says it must be cleaned down to bare with a wire wheel NOT a grinding disc. I assume you know the routine about warping.
Goach2 #1426244 10/08/2021 12:20 PM
Thanks, I was thinking I might get away from removing too much paint if I go from the back. Heat will burn it off the front anyway. I'll likely attempt it this way first and see.
More images
Goach2 #1426245 10/08/2021 12:20 PM
Crusty Old Sarge
Crusty Old Sarge
You really need to drill a hole at the end of the crack to stop the split prior to welding.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Goach2 #1426258 10/08/2021 2:30 PM
Thanks Tuts, I had heard of doing that before. Was waiting to see if it got suggested. Does it matter what size hole? I'm assuming you weld it up after?
More images
Goach2 #1426293 10/08/2021 6:52 PM
If your weld dot at the end of the crack is full penetration, you really don't need to drill the ends. But it's a good idea. 1/16 inch should be adequate. The bigger the hole, the more weld metal (shrinkage), and harder to fill.
Goach2 #1426521 10/11/2021 4:02 PM
If you have access to a TIG you can use heat dam or heat block putty to prevent warp and cut way down on paint damage.. A good TIG weld will require very little if any grinding.
Evan
Goach2 #1426525 10/11/2021 4:15 PM
Ex Hall Monitor
Ex Hall Monitor
If you're going to stop drill the crack make sure you're at the end of the crack. It's very common for folks to miss the end of the crack. If that happens the crack will continue to propagate. The most reliable method of finding the crack ends is to use liquid penetrant or magnetic particle testing. Welding the crack should remove the need to stop drill IF you weld the whole crack. Start the weld beyond where you think the crack terminates and end it past the visible other end as well.
Goach2 #1426802 10/14/2021 3:30 AM
More images
Goach2 #1426806 10/14/2021 4:04 AM
Looks good. I had to replace some of those weld-in nuts on the right side inner fender as well.
Goach2 #1426823 10/14/2021 1:40 PM
I have not done it but if you do some research you can find some guidance on duplicating and color matching your new paint to simulate the old patina. You could practice on some scrap until you figure out the best procedure/combination of paints. Fortunately it is a small area and if you take your time it might not even be noticeable to anyone that you had to touch up the patina.
Dave from Northern Kentucky
My 54 3100
Goach2 #1426863 10/14/2021 6:18 PM
Thanks Dave, the artistic paint stuff isn't really my thing, but I'm willing to try it. From what I've found, the paint code 830 is 'Commercial Blue'. Wondering where I can get modern codes for it.
More images
Goach2 #1426938 10/15/2021 3:39 PM
Can't get to the rear of the fenders as it's two pieces sandwiched:
[img]https://www.stovebolt.com/ubbthread...umber/35921/filename/20211015_091102.jpg[/img]
So from the front:
[img]https://www.stovebolt.com/ubbthread...umber/35922/filename/20211015_091054.jpg[/img][img]https://www.stovebolt.com/ubbthread...umber/35923/filename/20211015_102025.jpg[/img]
Some welds stood tall and were hollow. Not sure what setting is off for that. Got to the other side too:
[img]https://www.stovebolt.com/ubbthread...umber/35924/filename/20211015_110001.jpg[/img][img]https://www.stovebolt.com/ubbthread...umber/35925/filename/20211015_113129.jpg[/img]
I got a PPG code for Mariner Blue, which might be the American equivalent of Commercial Blue. Will see if I can get a small batch whipped up and do a comparison.
More images
Goach2 #1426940 10/15/2021 4:00 PM
So, I'd like to start cleaning up inside the fenders, but I'm hesitant to remove them as I've read alignment afterwards is difficult. If I leave the inner fenders attached to the grill/rad bits, does this make it easier to reattach the outer fenders later?
More images
Goach2 #1426950 10/15/2021 6:27 PM
More images
Goach2 #1426951 10/15/2021 6:32 PM
On your pics 3 posts ago, those show the mounting flange where the fender proper is lapped over it and spot welded together. Welding those corner cracks isn't an issue as long as you get good penetration. If your welds are hollow, you need to turn up the wire feed a touch. The ones that stand tall, especially if there's a sharp definition to the base metal means that you need more heat. It's a balancing act. If you're concerned about burn thru, you could use a backer made of copper (a piece of old copper pipe flattened and shaped to match the fender works well.) If you use a backer, you need to turn the heat a bit higher, as the backer will soak up some of the heat.
Goach2 #1426961 10/15/2021 9:06 PM
Thanks klhansen, I'm used to the more modern 'thin' panels. It's coming along now, just doing some de-rusting...
More images
Goach2 #1426976 10/15/2021 11:30 PM
I would suggest finding the stressors that caused those cracks and addressing those.
Goach2 #1426980 10/15/2021 11:57 PM
I think those cracks were just from the nature of the fender construction and the years of rattling down the road. One of mine had almost identical cracking. The fender to body mounting and the flexing of that assembly would definitely do it. If you stiffen up that point, then it'll just rattle and crack somewhere nearby.
A heavy application of undercoating would probably help dampen vibrations.
Goach2 #1426982 10/16/2021 12:09 AM
The support under the rad was flat too, so likely added to the stressors.
More images
Goach2 #1427073 10/17/2021 6:02 PM
If anyone was wondering, definitely glossy-black on these fender supports!
[img]https://www.stovebolt.com/ubbthread...umber/35964/filename/20211017_123052.jpg[/img]
More images
Goach2 #1427588 10/22/2021 2:38 PM
Wire-wheeling and rust converter continues, will have some pics to upload soon. I was thinking about painting the underside of the fenders with POR and then topcoating with bedliner. I did this with the belly of an old Terr-Jet and it seems to hold up pretty well. Unless there are better suggestions? wink
More images
Goach2 #1427753 10/24/2021 1:02 AM
Inner and outer fenders and cleaned up and rust converted:
[img]https://www.stovebolt.com/ubbthread...umber/36150/filename/20211023_190015.jpg[/img]
Next up paint..
More images
Goach2 #1427754 10/24/2021 1:07 AM
More images
Goach2 #1427755 10/24/2021 1:42 AM
I think that apron was designed to rust out. Looks like you're getting it dealt with. thumbs_up
Mine was full of gravel, like the truck had been submerged in a stream. eek
Goach2 #1428382 10/29/2021 4:20 PM
More images
Goach2 #1429244 11/05/2021 12:38 AM
Did a coat of boxliner on the inside of the fenders. Not much to look at, so here's the inner fender with two coats of Rustoleum:
[img]https://www.stovebolt.com/ubbthread...umber/36540/filename/20211104_203524.jpg[/img]
More images
Goach2 #1429400 11/06/2021 10:34 PM
[img]https://www.stovebolt.com/ubbthread...umber/36575/filename/20211106_183134.jpg[/img]
Nice coat of Penetrol while I have it all apart and can get in the nooks and crannies...
More images
Goach2 #1429406 11/06/2021 11:00 PM
Suggest you start a build thread. This one is getting a little far afield from "cracking fenders".
But it's looking good. thumbs_up
