4 members (Peggy M, Hotrod Lincoln, Bill Hanlon, Otto Skorzeny), 175 guests, and 6 robots.
Topics128,107
Posts1,056,221
Members48,436
#1427296 10/19/2021 11:24 PM
Looking for a source for front brake hoses. The truck is a 24000 gvw Dayton wheels I’m trying to figure out what front axle I have I’m gonna try to attach a pic of the old hose Thanks [img]https://www.stovebolt.com/ubbthread...AC6C25B-693D-4F98-A150-5A9857984E09.jpeg[/img][img]https://www.stovebolt.com/ubbthread...256084D-90AC-4897-911B-4A148D1F541A.jpeg[/img][img]https://www.stovebolt.com/ubbthread...187DAFD-A3DB-4AB1-898A-5AF16B066092.jpeg[/img][img]https://www.stovebolt.com/ubbthread...5E9C7F9-775F-4759-B8E8-57A163155A14.jpeg[/img]Kip
Your best bet is probably to take the old hose down to your local parts store and compare what they have in stock. They may even be able to identify it from your truck description.
Rockauto has the following for a '66 Medium Duty Truck
DORMAN H36697
Fits Front Left; C60; 25 In. Length; 7,000 Lb. Front Axle
or Front Right; C60; 25 In. Length; 7,000 Lb. Front Axle
3B Offline
Hy Kipparham, are you sure the banjo bolt section is not removable from the brake hose? Your pictures show up too small to tell. The possible hoses I checked, none had a banjo bolt connection.
