2 members (Erniegp, J Lucas), 89 guests, and 2 robots.
Topics128,054
Posts1,055,781
I've got a Buick 350 LT1, fuel injected, in my '50 3100. The engine sits level side to side but is an inch or two tilted down transmission side. Because of the engine mounts needing to be raised to accommodate the ac compressor, I don't have enough clearance on the floor to raise the transmission to make fore and aft level. With carburetion, it is necessary for the bowls and float to work properly...maybe not a concern for fuel injection?
Tail down is pretty normal. There is a desired angle that someone will post soon. Having to cut and modify the transmission tunnel is normal too.
I agree, most tilt down in the back, up to 8 degrees.
Crusing in the Passing Lane
3 to 5 degrees down for the engine and trans. is normal. Most intake manifolds are machined to keep the carb. level.
Ed
Before I removed my 235, I measured the pitch angle. It was 5 degrees tail down with the chassis level. Since you're using an injected engine, probably not a big deal how much as long as your driveshaft angles are in the good.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
U-joint working angles are 1/2 to 3 degrees, more or less under ideal conditions. Thats tail shaft to driveshaft, and driveshaft to pinion gear. As long as the oil pickup is still under oil, and the u-joints are happy, it will work. Setting level doesn't mean much when roads have hills and turns, means even less with fuel injection, just look at how some boat motors are mounted !
Just make sure that your engine/transmission drop angle is parallel to your pinion angle within a degree or two to keep the u-joints happy.
If you get no driveshaft vibration, leave it alone. Back in carburetor days they had cars in San Fransisco that seemed to do quite well on really steep angles. Ford vans were not only tilted but also offset to the right.
Evan
Rocket man Your in the range,make sure u-joints are happy and go for it if no noise you've got it !! It will show up if you go to pull on something like a stuck vehicle.
V
V Offline
Always was told about 3 degrees....
panic If you recall the c-1 corvettes were the other way nose down,even with 2x4's they just adjusted the floats.
vetttecrazy Remember how the C-1's had their nose down,so the body could fit. Zora got that to work !!
