4 members (Jon G, dt235sd, Wally / Montana, 1 invisible), 93 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#1426786 10/13/2021 11:27 PM
If I’m looking at the manual correctly I have everything loose. Both nuts are out. I can move it back and forth and after a lot of work I have moved it out slightly. Is this going to take a big stout puller? I want to make sure before I damaged anything. Thanks.
Crusing in the Passing Lane
I have always been able to pull one off from this position.
Ed
Thanks I’ll see if I can get it pulled.
7
7 Offline
Were you able to back off the brake shoe adjustment, that is normally what is keeping you from sliding the hub off. If the shoes are not the issue then the bearing may have spun on the axle tube and partly seized. Rig up a pusher from the back.
I didn’t mess with the brake adjustment I will check that first thing. I like the pusher idea also. I’ll get back on this in the morning. Thanks for the advice.
Loosening the pads did it thanks again!
