4 members (Hanks custodian, Nick in Manitou, Phak1, Wayne67vert), 123 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
#1425496 09/30/2021 4:16 AM
New member here. The fuel pump on the m135 is in the tank and isn’t working. I took it out the other day and turned impeller which woke it up and it worked fine for about three minutes and quit, seems permanent this time. There are 24volts getting there, not sure if it’s brushes, if they’re even available. Does anyone know the psi for these pumps? I’d then consider an external pump.
There are a number of military suppliers around, Midwest Military in Minnesota comes to mind. I'm sure a 24 volt in tank fuel pump is going to be expensive. It's probably not over 5 lbs psi. An aftermarket pump with a regulator may be the way to go.
Fred
I think too that getting one would be pricey, unless someone has a parts truck with a good pump. But then again the thought of 24volts going into a gas tank with an old used pump makes me nervous. Thanks for reply, I’ll get on the external pump idea.
PM sent
