0 members (),
50
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 350 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 350 | What size glass setting tape should i order for my vent glass replacement project? It shows my options as 1/16", 1/32", and 1/64". Thanks for the help. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It depends on the glass thickness.
The vent glass pieces might have been replaced already.
One way to know if you have original glass is to check for date-code "bug" etched into one of the lower corners of the glass.
Of course, a purist restorer might have already replaced those glass pieces and asked the glass supplier to put in the original "bug" codes in a different thickness replacement glass? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Measure the glass with calipers. Measure the channel with calipers. Subtract glass thickness from channel width and divide by 2. Use a tape with that thickness or a little larger. Try a short section of tape. There is no exact way to tell you. I've done several 55.2-59 windows and I think it was .045 tape. Can't remember. You are mistaken about your options. They are 1/32, 1/16, 3/64 (.045) and 5/64. Use decimal equivalents in your math. Glass used to be 1/4 (.250) Thick, now-a-days it is made off shore and is 6mm (.236)
PM sent.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Restoration Specialties & Supply Inc. sells different thicknesses of glass setting "tape". | | |
