Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (carbking, Ridgeback, baldeagle, 3B), 36 guests, and 0 robots.
Topics128,005
Posts1,055,253
Members48,418
#1422957 09/04/2021 8:59 PM
I just bought an Makita 18V 4.5/5 in cutoff grinder.
Will this be adequate for cutting off rusty bolts, etc customary of restoration/fabrication on my 1951 GMC 100?
Get a couple of extra batteries. I've got a Makita 4.5" that never slows down or stalls- - - -it's got a cord, however.
Sir Searchalot
Sir Searchalot
Yes, it is the go-to tool for all manner of cutting. Personally on those, I like corded. I also use a die grinder. The little brother. Those are air. Your unit is just called an "angle grinder". You have to really be focused and man handle it. You are talking 10,000 RPM. Always be sure to have the wheel rotating to pull itself into the cut. Gloves and facemask. A very useful tool. There will be times the thin disc with break/partially shatter due to various reasons. You can cut with it using a 1/16 think disc and grind with it using thicker discs.
DO NOT do what I did, I took off the guard and the handle. Don't use the .040 disc.
Those are good machines. The only thing I liked better was my Milwaukee. Always use safety glasses, shields and guards. Like Jerry says, plenty of batteries. Any heavy grinding will use them up quick. I've found three minimum, four is better. That way, when one dies, you will have a fully charged one at the ready. As long as you keep rotating them through the charger.
Winery truck Battery cut-off is great,take it to the junkyard with you,I use mine on a/c duct work,just all kinds of cuts.
We use Milwaukee grinders cutting rebar everyday . work well for us hilti discs are the best . Have tried a lot of different brands even hilti and Milwaukee come out on top
We grind a lot. We still use corded Fein and the made in Germany Metabo. We have good luck with Pferd abrasives. Years ago we used air grinders because electric got hot. We switched to electric quite a while ago. We have a couple of cordless if we need to cut soething out in the back of the yard, but I still like corded for in the shop.
Moderated by  MNSmith
