3 members (j05h79, Phak1, Jay R),
73
Mod | | | Forums66 Topics128,154 Posts1,056,837 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2021 Posts: 27 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 27 | New member here. The fuel pump on the m135 is in the tank and isn’t working. I took it out the other day and turned impeller which woke it up and it worked fine for about three minutes and quit, seems permanent this time. There are 24volts getting there, not sure if it’s brushes, if they’re even available. Does anyone know the psi for these pumps? I’d then consider an external pump. | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | There are a number of military suppliers around, Midwest Military in Minnesota comes to mind. I'm sure a 24 volt in tank fuel pump is going to be expensive. It's probably not over 5 lbs psi. An aftermarket pump with a regulator may be the way to go. Fred
| | | | | Joined: Sep 2021 Posts: 27 'Bolter | | 'Bolter Joined: Sep 2021 Posts: 27 | I think too that getting one would be pricey, unless someone has a parts truck with a good pump. But then again the thought of 24volts going into a gas tank with an old used pump makes me nervous. Thanks for reply, I’ll get on the external pump idea. | | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | | | |
