6 members (Gdads51, Hambone, TUTS 59, Otto Skorzeny, Guitplayer, Gray_Ghost), 101 guests, and 2 robots.
Topics128,084
Posts1,056,087
Members48,434
#1425134 09/25/2021 2:48 PM
As many of you know I’m shopping for a replacement motor for my 100K mile original 216. Ran across this one but don’t know what it is. It doesn’t look like a 235 to me. I’ve attached pics the owner sent of the CON, Serial, Casting, and Head numbers, as well as pics of the motor. Correctly iD’ing the motor will help me decide if it’s the motor for me.
Many thanks for the help!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
More pics…..
Chuck
1941 Chevy coupe
Appears to be a '55 -'62 235, low water pump, 4 screws on valve cover etc etc. Yeah 848 head, date code 1955.
1946 1/2-Ton Chevy
The engine number suffix ID's the block as a model year '56 235, manufactured in the Flint, MI plant, consistent with its casting date of December 29, '55. The Y designation indicates that the engine was originally in a Powerglide car, so it should have hydraulic lifters, unless swapped out later. The '848 head may be original to that engine, since that casting was introduced in '56. Here's a decoder that works pretty well through '57, but it does miss some early Powerglide engine codes. '41-'57 Chevy Six Engine Number Decoder Page.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
