| | | Forums66 Topics128,172 Posts1,057,038 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 51 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 51 | My local shop can't find the drums I need for my 1951 3600. Its an 8-lug pattern. The 11" drums he ordered are 6-lug pattern, and all the 8-lug drums are 12" drums. Can anyone offer some direction? Thank you, Roger Schroeder Marshall, MN | | | | | Joined: Feb 2019 Posts: 4,506 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,506 | Try posting in the “Truck Parts Wanted” forum. You may get a ‘bolter the just swapped to disc brakes.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Are you running Huck or Bendix brakes? 3600 drums in general are about as scarce as a chicken with lips, and Hucks are really unobtainium. I've never heard of an 11" 8-lug brake, unless it might be an oddball Huck type of some sort. Where are the shoe adjusters- - - -Hucks have a 1-shoe adjuster on each end of the wheel cylinder and pivot pins for the shoes at the bottom. Bendix has a single one between a set of floating shoes at the bottom. Jerry
