0 members (), 80 guests, and 0 robots.
Topics128,050
Posts1,055,644
#1424448 09/18/2021 5:47 AM
Casting on the diff is 3707340 or 3707343. Located on pass side.
The other code is a circle(like a zero with something in the center) and D1
This is in a 1955 series 2 3100.
Question 2: Why is there nothing mentioned about rear differentials in the 1955 factory assembly manual?
Thanks in advance
Jim
Jim
1955 Chevy series 2
6 cylinder, 3 on the tree
Short bed, step side
Casting numbers are different than part numbers 3707340 fits 1955-1962 Chevy. It is a GM HO-35. What are you trying to figure out. If you are trying to fix your third member you need a maintenance manual instead of an assembly manual. Assembly manuals usually cover body parts and complete components.
Thanks for the info crenwelge. First (only) helpful information I've gotten on these numbers. Can I ask where you found decoding info? I've looked all over. Well obviously not all over.
I want to change the ring and pinion from 3.90 to 3.08. I haven't seen anything lower than 3.38. That'll be ok.
Guess I've got to get it apart to see what's in it.
I'll also look into getting the maintenance manual.
Thanks again
Jim
Jim
1955 Chevy series 2
Moderator, Electrical Bay
As I recall you can't get a 3.08 for that one, Jim. 3.38 is available, but I believe that's as far as you can go. Good luck. A 3.08 12 bolt rear was available in the 1969 pickup and the width is good for these trucks.
~ Jon
Forgot to mention, if you want a wealth of information about your truck, use the GM Heritage pages. Here's the 211 pages for yours:
https://www.gmheritagecenter.com/do...ucks/1955-Chevrolet-Truck-2nd-Series.pdf
~ Jon
And here is the front page to this archive. More are being added occasionally:
https://www.gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.html
~ Jon
Along with being in the trucking business since 1964 and growing up in the gasoline business I was a licensed salvage dealer for many years. A book called the Hollander is what salvage dealers use to determine what interchanges and a lot of it is just remembering what worked last time you tried it. I will be 78 in a few weeks and there are not many of my generation left that still do things the old fashioned way. I think the 3. 90 and 3.38 fit in the same GM corporate housing. They call it a H033 at 3.90 and H0335 at 3.38. The 3.38 was offered behind automatics. The 3.08 was a Spicer which is a totally different animal. I still run a dozen trucks, have a couple of gas stations, but I dropped my salvage dealer's license a few years ago.
https://photos.app.goo.gl/u7JHgEqaPRRbUCZE9
