4 members (Phak1, WICruiser, GMCJammer51, NorCal52Suburban), 88 guests, and 1 robot.
Topics128,196
Posts1,057,395
Members48,471
I am building a paintbooth for my own personal use. Looking for filters there are several series available and I don't know which one to use. Any thoughts? Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Dave
Just about anything will capture overspray, but you really can't do much about vapor getting thru. "Dilution is the solution" for that. And where your shop is, no one is going to smell the vapors.
Or are you talking intake filters? Again, unless you're in a really dusty environment outside the booth, probably the least expensive filters will do the trick. You'd probably do fine with a MERV 8 rated filter that's 1" thick. The thicker you go, the harder your fan has to work.
It looks like the paint booth guys sell fiberglass filters that have sticky stuff on them, but you may not need that. The MERV rating is an HVAC thing for commercial ventilation system filters.
Unless you're talking about your compressor air supply filters?
I need intake and exhaust filters and looking on Amazon I see 45 and 55 series filters, I just do not know what I need. Dave
1941 Chevy
I looked at them. I think either one would work for you. Since you probably aren't talking production painting, I'd go with the cheaper option.
Thanks, I appreciate that! Dave
1941 Chevy
