5 members (49Chief, stlcardinalsguy, DadsFirstPickup, Bisbee, Pete1946), 79 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
#1423823 09/13/2021 11:49 AM
2 Offline
Can the rear bearing in a t5 trans be changed in the vehicle or does the trans need to be disassembled?
S Online: Content
Rear bearing meaning output shaft or input shaft (I would assume output)?
Output shaft...while the bearing itself isn't pressed onto the shaft, 5th gear is pressed on which prevents changing the bearing without disassembly.
Input shaft...can be removed and bearing replaced without complete transmission disassembly but the trans would have to be removed from the vehicle.
So, long story short, no T5 bearings can be changed while in vehicle.
Mason
1947 Chevy 3100
-57 Chevy 235
-95 S10 T5 Transmission
-97 Blazer 3.42 Rear End
If you're referring to the tailhousing bushing there is a special puller designed to pull the old bushing out and then you can drive a new bushing back in.
2 Offline
Yes tail housing bushing where the drive shaft slides into
