1 members (Shade Baby),
152
8
Mod | | | Forums66 Topics128,106 Posts1,056,214 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14235 02/16/2004 3:12 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | I'll soon be doing the swap from a 216 to a 235 and well, I really like faking people out, so I was wondering, is there a way to fit the valve cover from a 216 to the 235? | | |
#14236 02/16/2004 3:13 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | Oh yeah 1 more thing,,,,,ALOHA!!!! | | |
#14237 02/16/2004 3:36 AM | | Anonymous Unregistered | | Anonymous Unregistered | Yes - you can purchase a stud kit that has two studs going up from the rocker arms that will allow use of the 216 valve cover on the 235. I have even seen 261's with 216 valve covers. | | |
#14238 02/16/2004 3:56 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | XLNT! Is it a specialty kit or just studs from a hardware store, and I would love a 261, can't seem to find 1 here in Southern California, although I did just miss a factory short block still in the crate for $1000!!!! Day late, $1000 dollars short!! Mahalo Nui Loa!! | | |
#14239 02/16/2004 4:19 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Aloha Kimo,
Check the vendors for a (Wayne Valve Cover) Stud Kit. This is how it is usually listed (about $12.00). I could not find it listed by American Classic Truck Parts but Chevy Duty has it Jim Cart's and Patrick's also have it). It works on 1954-1962 235/261 engines (not needed for pre-54 235 truck engines).
Tim | | |
#14240 02/16/2004 3:46 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | There should be 261's out there. Check school busses and larger trucks of the 60's. Sometimes I see a whole truck for the price of the running 261 in it.
54 3100 with 235 62 flatbed dump C60 with 261
#14241 02/16/2004 5:13 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you have the 216 laying around, you can usually salvage the studs from it. I couldn't get one of the studs out of mine, so I bought the kit from Bowtie Bits. Only thing I didn't like about the kit was the seals were rubber, and didn't last. My friend machined some from urethane for his 261, I couldn't wait. When my seals gave up I used fender washers, and they leak less than the air vents in the cover.
Fred 52 3600 69 C-10
#14242 02/18/2004 7:08 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | Mahalo (thank you in Hawaiian)for all the replies. Hey if any of my brudda's out here in california hear of a 261 could you hook me up please? then I'll have a 235 in running condition to sell! I'm in LA county. AlooooHA | | |
#14243 02/23/2004 6:26 AM | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | I did the valve cover swap today.
I got the "new" valve cover and studs from an old 235 babbitt pounder at the salvage yard. But when I put it on my '59 235, it didn't seal well at all. I had oil dripping down the right side of the block :mad:
So, this leads me to believe that you need to use the old 216/235 style gasket instead of the one for the later 4-screw valve cover? Or, do you just use a case of RTV silicone and seal that sucker up? :p
Thanks, Steve | | |
#14244 02/23/2004 7:24 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by 53Therapy: I did the valve cover swap today.
I got the "new" valve cover and studs from an old 235 babbitt pounder at the salvage yard. But when I put it on my '59 235, it didn't seal well at all. I had oil dripping down the right side of the block So, this leads me to believe that you need to use the old 216/235 style gasket instead of the one for the later 4-screw valve cover? Or, do you just use a case of RTV silicone and seal that sucker up?
Thanks, Steve Covers have the same footprint, and the same gasket is used for both applications. Did you trim off the tabs that stick out of the sides? Also, be sure the edges of the cover are straight. You don't want to use rtv on this, if you have solid lifters you need to adjust them. A gasket sealer like Permatex #2 or yellow weatherstrip adhesive works good in this case. I am running with a cork gasket and no sealer, with a straight cover properly tightened an no leaks.
