1 members (Peggy M), 121 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
#1423577 09/10/2021 8:18 PM
So I got it all back together in the truck and was turning lock to lock. So it turns all the way left and then just barely to the right before hitting lock to the right. So it appears that the worm nut box is not centered on the worm. I’m not sure how that happened but it had to for there not to be enough steering to the right. So now I’ve got to do it again this weekend. I just knew when I had it together on the bench something didn’t seem correct and now I know.
I’m posting this so that someone else may not make the same mistake, and yes I’m feeling a bit stupid, not mad or frustrated just darn stupid for not following up on my intuition that something didn’t seem correct at the bench. But it shouldn’t take as long to get it all apart.
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Rebuilding mine this weekend as well...good to know!!
Mason
1947 Chevy 3100
-57 Chevy 235
-95 S10 T5 Transmission
-97 Blazer 3.42 Rear End
So I got it all apart and made some new seals/ gaskets this evening so tomorrow I’ll adjust the worm box and put it together.
Take your time and be thoughtful and it should work out well for you. It will definitely tighten up that loose steering.
More pix on Flickr
