0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1423420 09/09/2021 2:53 PM
Hello,
I have a 57 235 with the Pertronix kit in the original distributor. Do you need HEI plug wires for this or will stock style work? 12volt original coil.
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#1423443 09/09/2021 6:50 PM
Sir Searchalot
Sir Searchalot
Any wire except solid core. Some "HEI wire" ends won't fit your cap. Just buy Suppression or spiral wound normal wires.
#1423487 09/10/2021 1:19 AM
Make sure that your AAA subscription is current before you go very far, and make sure to never leave the ignition on without the engine running or your unit will fry and your coil will melt.
I had a faulty ignition switch which remained on once the key was removed. I am lucky that my truck did not burn to the ground overnight.
#1423531 09/10/2021 1:03 PM
Thanks for the info!
Blue 50
1950 3100 w/57 235
I guess I forgot to say I am trying to get my truck running good again after sitting in my garage for 6 years. I have owned it for 20+ years and have had the Pertronix in it for over 15+ years. I am chasing gremlins which is the reason for the questions (electronic ignition kit, plug wires, current condensers available, carb rebuilding, etc). FYI the current Napa/Echlin inventory at my local Napa is made in Mexico.
Blue 50
1950 3100 w/57 235
#1426764 10/13/2021 3:07 PM
Please stay on topic and keep it civil.
Another quality post.
Real Trucks Rattle
#1426766 10/13/2021 3:39 PM
If I remember correctly Pertronix instructions say do not use metal core plug wires.
#1427931 10/25/2021 6:52 PM
Rather have parts made in Mexico than China. Quality control seems to still be a thing south of the border.
1950 Chevrolet 3100 (Ol' Roy)
#1427945 10/25/2021 7:50 PM
Curmudgeon
Curmudgeon
Sitting for 6 years?
If it had Ethanol gas inside I would drain the tank ASAP.
Change the fuel filter(s) and fingers crossed that rust didn't get to it.
After 6 years the Ethanol breaks down to water and stuff that doesn't want to burn (even with additives).
#1428005 10/26/2021 3:38 AM
Crusing in the Passing Lane
And antique alcohol fuel will gum up valves and bend pushrods!
Ed
#1429732 11/10/2021 12:47 PM
Bluetruck 21 Have had the best service out of homemade HEI distributors,I guess there condensers are reliable (if they even have one) as I have used all v-6 types for donor distributors. Just make it look like what you took out,be sure it has clearance for oil up and down .
