| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 14 Junior Member | | Junior Member Joined: Mar 2005 Posts: 14 | Hi Guys,
Have a 46 1 1/2 ton and am trying to find out the different diff centre options.
can you get them as low as 3.08 etc... now I know that something this low will strain the 216 but just weighing up the otions as I am very new to the Big Bolts.
Cheers Jason.
46 1 1/2ton
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Unfortunately, I don't think gear replacement options exist for any of the big bolts (1.5 and 2 ton), or even 1 tons, especially pre-'47. It seems the replacement market is mainly for '47-up 1/2 and 3/4 tons. The only option is probably swapping in a later model axle, or an overdrive tranny.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Well, in the '47-up world, the 3/4 and 1-ton axles are the same. I've never figured out the H050, H052, and H072 designations, the differentials are the same, and everything else appears to be. Might be a brake issue. | | |
