5 members (Goach2, 50Chevy3100, Shade Baby, Cosmo, 1 invisible), 64 guests, and 2 robots.
Topics128,179
Posts1,057,133
Members48,463
Ok, ok, I know im going to get ALOT of flak for even posting something as sacriligious as this, but...
I am seriously considering puting a chevy 235 in my half ton GMC. This is definately Plan B for me, but using both the "third times a charm" and " three strikes and you're out" rules, I cant get ahold of a GMC engine that can be even rebuilt around here.
However 235s are a dime a dozen and I have seen this setup in several GMCs online. Trouble is, I cant find a goid description of what I need to consider... ive got that 235s are shorter... but what about bellhousing, transmission (wanting to keep my GMC 4 speed), etc.
Does anyone have experience doing this swap?
Thanks!
1947 GMC half-ton
Chevy and GMC engine blocks share the same bellhousing bolt pattern, so that's not a problem. 47 was the break point between the crash box and the SM-420 transmission on most of the trucks, so it's possible you've got the later model transmission. Does your shifter have a reverse lockout trigger? If not, you've got the SM 420. You'll need to fabricate a bracket to move the front motor mount back a couple of inches and do whatever adapting the exhaust pipe and throttle linkage requires, but overall it's a pretty simple swap. Good luck!
Thanks Jerry! I do have the lockout lever, so I must have the "crash box"... im assuming that means non-syncro. Does that change anything?
Thanks, Zech
1947 GMC half-ton
Crusing in the Passing Lane
GMC engines are usually easy to find, up to 302 cubic engines, I would look some more, carefully. Once one gets organized, they usually appear. Some appear in milk trucks, vans, etc. SN behind the starter stamped on machined surface start with displ@cement, I e 270xxxx. Valve cover always different than Chevy valve cover. It would save a lot of work if you can find a proper GMC engine.
Ed
Go over to the OLDGMCTRUCKS site and contact Motion Guru. I believe he has GMC engines. Located in Yacolt. I have 2 302"s but I'm In Colville.
Joe
just retired and finally making headway on my project truck. 1940 GMC AC152.
Although I've got a couple of crash box 4 speeds stashed away, I'm no expert concerning the differences in them. I'm reasonably sure the Chevy engine will also bolt up to that bellhousing, which has a different transmission bolt pattern than the 48-up synchronized boxes. Definitely follow the leads the other guys have given you. I've got one GMC engine on hand, a 228, but I'm in middle Tennessee- - - -probably more of a road trip than you'd want to make!
If I remember correctly, the GMC engine uses a four bolt flywheel, the 235 will have six.
My Blog
Early GMC’s use 4 bolt flywheel, later ones use 6 bolt. I suspect modern 270’s (not wartime) and 302’s all have 6.
Ed
