2 members (baldeagle, homer52),
36
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | I need recommendations/suggestions while trying to resolve steering wander issues I decided the steering feet box needed rebuilding also replacing the drag link. I’ve already changed tie rod ends and tightened everything else but still had play and wandering in the steering. The pitman would wiggle just slightly so after removing some crud I gave the pitman a wiggle and it came off without using a puller. What does this mean do I need a new pitman arm, I hope not as there aren’t any available for someone wanting to retain manual steering 57 Chevy 3800 1 ton dual 235 cylinder 420sm trans | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | If the splines on the pitman arm and the sector shaft aren't worn excessively, you should be able to reinstall it and tighten the nut so it doesn't move. The splines are tapered a bit so it should tighten up. If that doesn't fix it, you'll need to drum up a replacement pitman arm and maybe a sector shaft or complete steering gear.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | If the splines on the pitman arm and the sector shaft aren't worn excessively, you should be able to reinstall it and tighten the nut so it doesn't move. The splines are tapered a bit so it should tighten up. If that doesn't fix it, you'll need to drum up a replacement pitman arm and maybe a sector shaft or complete steering gear. Thanks for your input, I had noticed the tapered spline and after looking closely at the teeth on sector shaft and the arm teeth they looked fine. So I put it back together and tightened it down by just adjusting the lock washer placement and I was able to get no movement. So I went ahead and pulled out the box and column and have them on the bench going through it. I have a rebuild kit for the box so I’ll see what I need to replace. Thanks again | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | When you reassemble the steering box, and you're sure everything is installed and adjusted correctly, the nut holdng the Pitman arm on needs to be VERY tight- - - - -like 200 ft/lbs or so. There should be no possibility of any movement between the sector shaft and the Pitman arm. It's usually necessary to use a dedicated puller and a lot of force to remove the Pitman arm from a steering gear. Jerry
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Anyone have any ideas for getting the bushing out of the side cap? | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Carefully cut a slot in the bushing with a carbide burr in a Dremel tool. Once the press fit is relieved, it can be driven out with a small chisel. Try not to groove the housing by cutting too deep. Jerry
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Thanks I’ll give it a go in the morning and let ya know how it comes out | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | So I’ve got it apart new bushings and bearings installed and man those new bushings are tight it’s difficult to get the sector shaft installed and drawn into sector shaft adjustment cap. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Use a button hone like the one that's for polishing brake cylinders to carefully fit the bushing to the shaft. I'd use the more conventional term for that kind of hone, but the hall monitors would get their manties in a wad! Jerry
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Yes hot rod, I have a home for wheel cylinders and I honed the bushings slightly, put all together and I’m getting 3 3/4 turns lock to lock which seems not enough compared to before rebuild. I pulled apart to make sure sector teeth were center to ball nut and put it back together and so that’s where I’m at. | | |
