0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | Anybody have recommendations for a 52 1/2 ton master brake cylinder? Seems to be plenty available at parts house and on internet. Mine is not rebuildable.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | You probably should go for a dual reservoir MC, new lines. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Yours can be sleeved and then rebuilt if that's the way you want to go... Search White Post Restorations. Mike B  | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Check out Brothers Truck parts videos on brake conversion!
| | | | | Joined: May 2015 Posts: 11,002 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,002 | I bought a new replacement from RockAuto. I was pleasantly surprised when I saw "USA" in the casting. It was a Raybestos brand.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | My replacement was quite expensive but it looks like a cheap ugly POS with a plastic lid. For a few dollars more, in hindsight I should have had the original resleeved. Nobody is looking under my truck, but I know and it bugs me. | | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | Thanks, that is the same thought and concern I have. Will disassemble mine and check bore to see if I can hone it out for a rebuild. If not I will probably go with Raybestos. Again, thanks everyone. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | It's been a while since I've been into one of the frame-mounted master cylinders, but I believe they're bored straight through, with threaded plugs on both ends. If so, building a machining jig to bore and sleeve one shouldn't be terribly difficult. If anybody has replaced one recently, I'd be interested in obtaining the old one to experiment on. Drop me a PM if that's something somebody could provide. Thanks! Jerry
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I bought one from lmctruck.com just 3 months ago. I am very happy with it. They have new and remanufactured. I bought the new one for $75. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Stove I hate those plastic lids,once it sticks your done !! | | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | Classic Industries has a new one for $89, shows a metal cap. Considering it. | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I converted using a dual reservoir with new lines and cylinders. With 4 drum brakes I searched one with the similar application. This model had the bolt on lid which allowed me to install a lid with the fittings to pump fluid into the system. I feel better with this system and gives good braking. Doesn't have power assist but it stops when I need to https://www.brakepartsinc.com/raybestos/catalog-part-search.html?PartNumber=MC36233
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | I just bought a new Raybestos MC. It's made in China. Hopefully it will be OK.
Dual reservoir MC doesn't help when it's the MC itself that fails.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | Dual reservoir MC doesn't help when it's the MC itself that fails. Generally the two reservoirs are on different circuits. The theory is that if one fails, you will still have brakes on the other one (either front or back). Half the brakes is better than none of the brakes. | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | I wonder how many people have actually experienced a brake faiulure of any kind with a two-chamber MC? (I have, BTW) It's an event that definitely increases one's pucker factor, no matter which end of the system fails! It's true that "a little brake is better than none"- - - -but until it actually happens, few people know what to expect. The only setup that actually provides a somewhat "normal" stop is the "dual diagonal" system where one rear brake and one front are plumbed to each chamber of the MC. That one takes some extremely sophisticated engineering and plumbing. Jerry
| | | | | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | My dual MC failed in the driveway so it was OK. There is a long steep hill leading to a coffee shop we regularly visit. If the MC had failed on that hill, we could have had a serious accident.
When it failed there was no warning - pedal went to the floor - no brakes - front or rear. After the new MC was installed the brake warning light was one since the rear brakes were bled first. It went out after a couple of hard stops.
A long time ago, we had the rear brake line rust out. In that case, the dual MC worked as expected. The brake warning light came on but the truck could still be driven until the line was replaced.
Dual MCs would provide safety, but I think they are only found in race cars.
