1 members (dunfire),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | This happened several months ago and I’ve been too embarrassed to post it in the forum, so here goes……
On the way from San Antonio to New Braunfels (35 miles) my three-on-the-tree started jumping out of third gear. I would clutch it and drop it back down into third and it would be good for a few miles, and then suddenly jump out of gear again. I was worried but continued, and had a good day with my truck buddies. On the return trip the tranny wouldn’t stay in 3rd gear for more than 100 ft. Then it got so bad that it wouldn’t even go into 3rd. I limped all the way home in 2nd gear. Anyone want to take a guess what the problem is?
Thanks!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: May 2015 Posts: 11,113 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,113 | Could be a worn synchronizer, first not allowing it to be fully engaged, then blocking it completely. I think you're going to have to open the tranny up to see what's going on.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I would check the linkage first. It may be so sloppy that it doesn't go into gear all the way. The shift forks in the shift cover wear and they jump out of gear but I don't think it would get progressively worse that quick. Have you checked the oil in the transmission? If it isn't the linkage, there is a good chance you are ready for a transmission rebuild. | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Since you have conveniently forgotten to mention which vehicle you were driving, it's hard to give any specific suggestions. All of the ones in your list have torque tubes, however, and one just might have a vacuum-assisted column shifter. Those things were notorious for getting stiff and not letting the transmission go into gear, or get partially engaged and wear out the drive lugs of the gears. In any case, a disassembly and inspection is probably in order, followed by a search for some scarce and very expensive parts. Good luck! Jerry
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | My apologies Jerry! It’s the 3-speed in my 1950 Chevy half ton.
I’ll crawl underneath it this weekend to check on the linkage, but I’m not expecting to find anything out of adjustment. I figure it’s in the gears, or synchronizer, as klhansen suggested.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Unfortunately, the most likely culprit, the 2-3 synchronizer assembly, is scarce, and extremely expensive when you manage to find one. You're more likely to be able to find a complete transmission from someone who has removed the stovebolt six and column shift 3 speed and replaced them with a "belly button" ("Everybody's got one") small block V8. Jerry
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Sounds like yours went quick. One day the 3-Speed in my '66 GMC popped out of 3rd. Overtime time it would pop out a little more and a little more. It finally got to where I had to hold it in 3rd. Then I was fighting it to stay into 3rd, lol. Bad synchronizer. Put in another Trans and my misery was over.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
