2 members (‘37ChevyPU, GusG),
69
Mod | | | Forums66 Topics128,185 Posts1,057,281 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I'd like to have a discussion on what areas of the 58/59 Chevrolet interior were painted different colors. I'm not concerned with the actual colors, just want to know what areas got taped off for a two-tone paint job. My research only has the top of the dash, door panel inserts and the steering wheel/column as being painted a different color. Did any of the floor, steps or riser get two-toned? Thanks, Mike B  | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | It may be helpful to check out Jim and Sabrina's well documented restoration of their 1959 apache. There is a wealth of information, including interior paint scheme. http://www.59apache.com/index.html
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | It may be helpful to check out Jim and Sabrina's well documented restoration of their 1959 apache. There is a wealth of information, including interior paint scheme. http://www.59apache.com/index.htmlThat's a great document and when looking at the interior colors there I see where the steps and riser are painted Charcoal when the doorposts are Silver-beige. Is that the way Chevrolet did it in '59? For a production truck that seems like a lot of extra work to keep the different colors all separated. Does anyone have factory pictures of it being done like that? Mike B  | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Thanks for the color chart, but that doesn't show what areas of the cab got different colors... Mike B  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Search the Internet for 1958 (and/or 1959) Chevrolet Truck Color Sales Brochure.
You would have to buy one - I cannot find one "online". | | | | | Joined: Oct 2019 Posts: 113 59 Apache 3100 | | 59 Apache 3100 Joined: Oct 2019 Posts: 113 | Found a sales brochure for 1959.  Has a ton of info but page 63 mentions the "charcoal" color in regards to "flooring" 1959 Chevy truck sales brochure
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
| | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | My '58 is finished as it was when it came out of Willow Run, Mi. Lugo Restoration did a spectacular finish on the interior details. I can post the pics in the gallery section or in this thread. Let me know what specifics you need. | | |
