4 members (cmayna, 52Carl, CATMAN, J Lucas), 126 guests, and 2 robots.
Topics128,195
Posts1,057,380
Members48,471
When I pulled the drums to put new brakes on the truck, I noticed some paper sticking to it, but wasn't sure what I was looking at. Didn't find anything on classic parts, but when I checked out LMC's site, I see that there are actually gaskets that are available for the inside of the drum. What are these for? Is it advisable for me to get a set? I still haven't moved the truck since the brakes and king pins were changed (waiting for some new front tires to arrive), so if I need them, I want to order them and get them on before it goes anywhere. Thanks for the help, Lee
"When I rest, I rust"
1951 3100 5 window w/ '56 235
Riding in the Passing Lane
You don't need them. They were put there to keep grease that may leak from the axle seal from getting to the drum surface. Years ago they didn't have the quality seals we have now. Thats why they had slingers around the hubs to catch the grease & kick it outside the backing plate. They don't put stuff like that vehicles anymore.
George
1972 Chevy c10 Cheyenne Super
Those gaskets between the axles and the drums are to try and keep potential gear oil leaks off the brakes. You'll notice there's a cup of sorts inboard of the axle flange with a hole that directs grease to the outside. If the gasket wasn't there, gear oil would run down the inside of the drum to the shoes.
I got gaskets for mine from The Filling Station.
Thanks, guys. I think I'll get some, just in case. I only saw them on the back drums, though. Are they meant for all 4?
They were used on front and rear, but since the front drums are riveted to the hub, they're hard to replace. I didn't bother with mine.
