1 members (MikeE), 121 guests, and 2 robots.
Topics128,129
Posts1,056,360
Members48,441
#1421331 08/21/2021 1:28 AM
Could someone ID the engine numbers
This is no longer fun
latroca52 #1421365 08/21/2021 10:49 AM
F56Z=
F = Flint, Michigan truck engine assembly line
56 = 1956 model year
Z = ? type of truck and series designation (maybe someone can help here?)
0110668 - 1000 = 0109668th truck off the Flint engine line that model year
The head casting code and block casting code were used in 1956 (and they were used in other years.
To determine the year of head/block, find and post the following codes:
head date casting code
block date casting code
latroca52 #1421380 08/21/2021 2:21 PM
Latroca', the F56Z engine number suffix IDs the engine as a '56 model year (as Tim said), 235 "regular" 140 HP engine, used in 1500, 2100, and 2400-series cars. The '848 head casting was used from '56 - '62, so a common casting, and considered "desirable" since it has the smallest combustion chamber size of any 235/261 head, for somewhat higher compression ratio (about 8.25:1 as produced, maybe a quarter point higher).
The date codes that Tim mentioned are found as follows: block casting date code is just behind and slightly above the starter. It should have a trailing "5" or "6" digit, since the engine number confirms the '56 model year (production starting in Fall of '55). The head casting date code is under the valve cover, about 2/3s of the way toward the rear of the head, facing the driver's (port) side of the head.
If the head casting date suggests it is a later unit, and perhaps swapped on at some time, it may be important to know, since the rocker assembly oiling scheme changed in '58 and '59. Pre68Dave's blog explains the 235 Rocker Oiling differences well.
Cheers!
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
latroca52 #1421488 08/22/2021 3:33 AM
Thanks guys
