3 members (klhansen, dt235sd, 1 invisible),
67
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 73 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 73 | Hey guys. So I’m trying to figure out what I want to do on my inner fenders and wheel side inner skirts. A couple of the fenders I’ve had sandblasted and they are bare right now while I repaired some rust spots. A couple of the fenders are new so they have the edp primer on them. Some of the chassis parts included the frame I’ve shot with PPG Deflfleet essential paint. So my question is what are you guys shooting in your inner fender areas? I believe the original was painted the body color. Are you guys painting like the original with the same body paint? Are you going black with a different paint or are you painting in some type of an under coating? I like the idea of an undercoating or something like that for paint chips from rocks. I’m going to be shooting the truck with Deltron, which is kind of pricey, so if I can do inner fenders with something else that would be great and get away with only one gallon of deltron. Thanks for any thoughts.
Adam
Adam
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The answers to all of your questions are yes, or no, depending upon what year truck you are working on.
Adam
| | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | I painted the inner fenders on mine with epoxy primer and then 3 coats of satin black rustoleum. Looks good. John 1949 gmc 1-ton | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I painted the inner fenders on mine with epoxy primer and then 3 coats of satin black rustoleum. Looks good. John  I only use epoxy primer followed by one coat of satin/semi-gloss epoxy black. | | |
