| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 10 New Guy | | New Guy Joined: Oct 2003 Posts: 10 | Guys, I hope you can help. I inherited my father's 1965 GMC 4000 with a 305 C V-6 4-speed, 2-spd rear axle. The radiator has begun to pour coolant. I removed it , and the repair shop tried & it is too rotten to repair. It is the original radiator, Harrison is embossed on it, but I have not been able to find a # anywhere. All parts houses and GMC dealerships have not been able to help find a replacement radiator. Can anyone please steer me in the right direction to find another radiator? Thanks, dyna | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some of the repro dealers should have'em [ fer instance, Jim Carter ] but if the 4000 series doesn't have the same rad as the 3000, a good rad shop should be able to recore yours for less than new - check another place! Bill | | | | | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | I'm not sure ware you are located but I have what apears to be a good one I just pulled out of a 61 chevy 2 ton truck if it will work and you want it. It was cooling a 348 when the truck was parked...it had clean coolant when I pulled the engine. I can get you some pics if you are interested. | | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | I would have your radiator recored. Any radiator shop be able to handle it with on problem. | | | | | Joined: Mar 2004 Posts: 23 Junior Member | | Junior Member Joined: Mar 2004 Posts: 23 | You may be able to get lucky from a salvage yard, or from one of the guys above. The best I have found in the northeast is
Maine Auto Radiator MFG CO Inc 14 Forrestal Street, Lewiston, ME 04240 (207) 784-0189 They still manufacture the original type of radiators. Give them a call, they may be able to point you to someone closer. | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Dyna, looks like rcurrier has the best deal -- if the radiator fits, wear it!
Good advice all around -- thanks guys!
Aschubox! Where ya been? Didn't we chat before about home??
Regards, John
~ One of many.
