| | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 58 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 58 | Hi - quick question for those of you that might have loose parts lying around... can anyone give me length x width x height, and possibly the weight, of a 47-54 Chevy truck rear fender? Trying to have a used pair shipped and working on what shipping will be.
Thanks! | | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | 57" x 28" x 12" and about 20 lb. each. I didn't get exact dimensions, so you might add a little bit. They won't nest together very well, and it would be best if shipped in separate boxes. You don't want to end up with a fender that's bent in two.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jun 2021 Posts: 58 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 58 | | | |
