2 members (carbking, RLB), 157 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#1420888 08/17/2021 2:33 AM
Well, it's running and it's been moved it out of the barn as per request. I've installed a number of new parts including a tank but ID of the engine still eludes me, I hope you can help. The truck is titled by the door post number but the number behind the distributor doesn't mach any reference I can find. Poorly stamped at the beginning 006101F54Y (the 6 may be a 5 or other) and with raised numbers reading CON 4 1133. Oddly the block is painted orange while the head is black. The head looks period with the valve cover held by two nuts. It is marked 370 1887 GM-4 CON 12. The engine pegs the 30 lb pressure gauge and I suspect it's a newer 235 block with an older and perhaps original head. Can someone confirm this? Thanks Jeff
F54Y indicates:
F = Flint, Michigan engine plant
54 = 1954
Y = RPO (regular Production Option) 313 = ???
In 1953, the valve cover would be attached with 2 nut on the top of the valve cover
In 1954, the valve cover would be attached with with four screws on the lower edge/lip of the valve cover.
Find and post the the following codes
Head casting code
Head date casting code
Block casting code
Block date casting code
Thanks so much tclederman. The head casting number 3701887 appears to have been used on the low pressure 216 in 1953. I believe I've read that a 216 head can be used on a 235 and I suspect this is the case. It will take a couple days but l will post the remaining numbers requested to help further clarify what l have. Thanks again!
216 heads have 15 head bolts.
Pre-1954 235 heads have 15 head bolts.
I think the heads are interchangeable (Would someone please post a correction, if I am wrong?)
1954 and later 235 heads have 18 head bolts.
Here is some head bolts information.
Here is some information on Stovebolt Engine heads and rocker arm lubrication.
Jeff, head casting # 3701887 is an 18-bolt 235 head, not a 216 head. It is interchangeable to the '54 and later 235 heads, so compatible with your F54Y engine/block.
By coincidence, I have a '53 235 in my shop at the moment that I picked up as a rebuildable core - engine number prefix LAQ - from a Powerglide car (which was the first of the "full pressure" 235s, with insert rod bearings, as used in the '54 and later 235s). And it has the 3701887 head, original to the '53 "full pressure" engine.
A few photos of the numbers, just FYI. First shows the head casting # 3701887. Second photo shows the head casting date code (valve cover removed to see it) - very late '52 casting for the '53 model year. Third photo shows the block casting # 3701481, and the fourth the block casting date code - again very late '52. Last photo is just an overall of the engine as it was pulled from the '53 Bel Air (the Powerglide transmission and torque tube rear axle assembly from the same car are in the background).
Hope that helps.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
F54Y indicates:
54 = 1954
Tim,
I'm confused with where you came up with "Y" = RPO 313...I don't see it in your link.
I found "Y" = Passenger Car 235 w/ Powerglide. This would make it a hydraulic lifter engine...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks to all who responded. For my purposes I could not be more pleased. The 53 head gives that archaic appearance and bearing inserts make rebuilding easier l would think. Hydraulic lifters would help explain why it runs so quiet.
