0 members (),
60
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 1 Moderated | | Moderated Joined: Feb 2021 Posts: 1 | uness i give it lot of throttle.it pops thru intake and quits.unless i give it lotta gas.. 235 3 pd 54,000 orig miles. i upgraded points to Perctonic.. new plugs.wires.fuel pumpfilter. drives great once going. no pinging.i set timing by turning distributor till idles the fastest,then retard it a bit.my old timing light was destroyed in my shop fire in 2013. rebuilt the carb,set air screw. .what do you think?
Ken in Alberta
what goes around.comes around.
| | | | | Joined: Mar 2014 Posts: 4,484 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,484 | Can you tell us more, Ken? Do you mean backfiring? Often that can be caused by a too lean condition and that would be supported by the need to give it more gas. As for the Pertronix, I'm not a fan of those, but we'll ignore that for now. Carburetor? Rochester B? Have you checked for intake vacuum leaks? Maybe at the carburetor to manifold? That will cause a "too lean" condition.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | First, degrade the "upgrade"- - - -there are two kinds of Pertronix units- - - -the ones that have failed, and the ones that are about to- - - - -then fix the accelerator pump. Jerry
| | | | | Joined: Nov 2020 Posts: 71 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 71 | Accelerator pump sounds to be kaput. | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Put a timing light on your Christmas wish list. In the meantime, borrow one.
When I rebuilt my carb, there was some hard light coloured residue restricting the jet. It needed to be removed with a welding tip cleaner as solvent and compressed air didn't remove it. The 0.057 jet was effectively reduced to probably less than 0.050. It caused a lean condition.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Unless you damage it, this light will last for decades. When my Snap-On delay flash light quit after 20-something years when somebody let it hit the floor, the Innova cost less than getting the Snap-On light repaired would have. https://www.innova.com/products/pro-digital-timing-light-5568aJerry
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | (1) TEST the accelerator pump to see if it is functioning. Leather pumps are impervious to ethanol, neoprene pumps are NOT. If it is not functional, replace with leather. (2) Upgrade the ignition to points/condenser. (3) Set the dwell with a dwell meter (4) Reset the timing using a timing light. If you don't have one, a guaranteed 50 year-old one from Ebay (opinion) is superior to the current versions made in someplace I cannot read the name.
The other Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try advancing the timing a little. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | hit your amazon link for the timing light and the computer popped up 110.99 for that unit on ebay
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | There are several models, some with more features than others. Be sure you're comparing apples to apples. I really like the dial-back feature on timing advance to check centrifugal and vacuum at cruise speed, and plotting the advance curve by carefully increasing the speed a few hundred RPM at a time. Jerry
