3 members (TUTS 59, Hugh63c10, Phak1), 212 guests, and 3 robots.
Topics128,089
Posts1,055,988
Members48,430
#1420559 08/14/2021 2:21 AM
Moderated
Moderated
uness i give it lot of throttle.it pops thru intake and quits.unless i give it lotta gas.. 235 3 pd 54,000 orig miles. i upgraded points to Perctonic.. new plugs.wires.fuel pumpfilter.
drives great once going. no pinging.i set timing by turning distributor till idles the fastest,then retard it a bit.my old timing light was destroyed in my shop fire in 2013. rebuilt the carb,set air screw. .what do you think?
Ken in Alberta
what goes around.comes around.
Moderator, Electrical Bay
Can you tell us more, Ken? Do you mean backfiring? Often that can be caused by a too lean condition and that would be supported by the need to give it more gas. As for the Pertronix, I'm not a fan of those, but we'll ignore that for now.
Carburetor? Rochester B? Have you checked for intake vacuum leaks? Maybe at the carburetor to manifold? That will cause a "too lean" condition.
~ Jon
First, degrade the "upgrade"- - - -there are two kinds of Pertronix units- - - -the ones that have failed, and the ones that are about to- - - - -then fix the accelerator pump.
Accelerator pump sounds to be kaput.
Insomniac
Insomniac
Put a timing light on your Christmas wish list. In the meantime, borrow one.
When I rebuilt my carb, there was some hard light coloured residue restricting the jet. It needed to be removed with a welding tip cleaner as solvent and compressed air didn't remove it. The 0.057 jet was effectively reduced to probably less than 0.050. It caused a lean condition.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Unless you damage it, this light will last for decades. When my Snap-On delay flash light quit after 20-something years when somebody let it hit the floor, the Innova cost less than getting the Snap-On light repaired would have.
https://www.innova.com/products/pro-digital-timing-light-5568a
Carburetion specialist
(1) TEST the accelerator pump to see if it is functioning. Leather pumps are impervious to ethanol, neoprene pumps are NOT. If it is not functional, replace with leather.
(2) Upgrade the ignition to points/condenser.
(3) Set the dwell with a dwell meter
(4) Reset the timing using a timing light. If you don't have one, a guaranteed 50 year-old one from Ebay (opinion) is superior to the current versions made in someplace I cannot read the name.
The other Jon.
The Carburetor Shop
Riding in the Passing Lane
Try advancing the timing a little.
George
1972 Chevy c10 Cheyenne Super
hit your amazon link for the timing light and the computer popped up 110.99 for that unit on ebay
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
There are several models, some with more features than others. Be sure you're comparing apples to apples. I really like the dial-back feature on timing advance to check centrifugal and vacuum at cruise speed, and plotting the advance curve by carefully increasing the speed a few hundred RPM at a time.
