Topics128,107
Posts1,056,225
Members48,436
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Hello everyone, So I got the carburetor rebuilt only to find out that the fuel pump had quit. I’ve got it off and cleaned up waiting for the rebuild kit to arrive. The question now is should I paint the pump and and if so what is the historically correct color for use on a 1940 truck? Thanks for your help!
Crusing in the Passing Lane
Fuel pumps are usually left the color of the casting which will not rust. Ed
Agree, no paint, just bare metal...any steel items like the bale for the sediment bowl and screws would have been tin or zinc plated.
Mike B
Bare metal it is then! It’s back together and back on the engine. She started up and ran well so that’s a victory! Thanks for the input!
