Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (moparguy, baldeagle, DaveV, jmoore, dt235sd), 40 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#1420271 08/11/2021 4:56 PM
As per the attached picture I am trying to determine if this is a Big Bolt 1.5 /2 ton hood or one for the lighter trucks.
I cannot seem to determine by just looking at comparable truck pics.
For reference the tape measure dimension is 56" .
Thanks in advance!
Mike
1951 Chevy 1/2 ton w/ 1959 235
1971 Chevelle
2 Offline
You need the side view of the hood
A bit too much is out of frame of the image to tell
The curvature at the back edges makes it obvious to the experienced eye.
-s
2MT
As requested attached are 2 side pics to help make a determination
Will these work for you?
Thanks!
Mike
1971 Chevelle
Isn't the big bolt hood wider at the front? If you need it I can measure between the front corners of my "little bolt" hood.
If you could send me that dimension that too will help support what I have.
Mike
Mike
1971 Chevelle
2 Offline
That’s a 1/2 to 1 ton hood
The 1-1/2 and larger trucks aren’t round at the back bottom they have a shape curve for the larger fenders
-s
Thanks 2MT for confirming that.
That response is what I was hoping for!
Much appreciated.
Mike
1971 Chevelle
Mike, I think you've got your answer, but measured my hood anyway. The front corner to corner measures right at 30 inches.
I'm not positive that's different than the big bolts, but the grilles are different in some way. I thought it was width.
Thanks for the dimension Kevin!
Mike
1971 Chevelle
