1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
#1419827 08/08/2021 11:29 AM
I have a nice 236 in a 62. Date code is appropriate for truck. Its painted blue as I believe is correct. I have to paint a new valve cover. Does anyone know of a close match in a spray can that I can buy on the shelf?
~ HB
1962 Chevrolet C10
1962 Suburban
AD Addict & Tinkerer
The Chevy blue is a very common color and can be bought at most auto stores that sell engine paint. Here is one from NAPA. https://www.napaonline.com/en/search?q=Nty%3D1%26N%3D2500057%2B2605722%2B2806584%2B116531700%26Score%3D0.72&referer=plp&partTypeName=Spray%20Paint&keywordInput=chevy%20blue%20engine%20paint&scene=partTypesScene2&fullyQualified=false
Here’s another from O’Reilly’s. https://www.oreillyauto.com/detail/...-150?q=Chevy+blue+engine+paint&pos=3
Phil
Project Journals
Stovebolt Gallery Forum
Great thanks for lead.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone,
FWIW, I was under the impression that the truck engine color was not the same as the common passenger car 235, "Chevy Blue." This article showing various engine colors by model year, posted by Jim Carter and attributed to Robert Hensel, Technical Advisor Coordinator for the Vintage Chevrolet Club of America, suggests that the '62 truck 235 should be "blue gray," and not the same as the passenger car blue. A number of the entries are based on good assumptions as noted, including the one for '62 truck engines, so there is some uncertainty. The original author's contact info (if still valid) is listed in Carter's post.
I will say that the paint mentioned earlier and stocked by the local stores - Dupli-Color DE 1609 "Chevy Blue" - is fairly dark, with a gray tint. Photo shows an example '53 235 valve cover that I refinished with it last year (for a Powerglide car 235). The Dupli-Color "Chevy Blue" paint is certainly darker than the blue of the engine in your earlier post. Perhaps it's more true to the article? Beyond that, and unless the vehicle is intended to go to vintage judging, I think the choice comes down to personal preference.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
If you are interested, here is Robert Hensel's original article in the June 1996 issue (pages 14-15) of Pickup 'n Panels in Print (PPIP).
Tim, thanks for the pointer. I forgot you had the article posted. Nice to see as originally written.
Doug
Unfortunately Bob Hensel passed away a few years ago, he was a great resource that will be missed...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks all
~ HB
1962 Chevrolet C10
1962 Suburban
Fox Offline
On my 261 I went with a blue color from Duplicolor. I recall using Chevy blue 1609 and not liking it as much. The colour I actually ended up using was GM blue-1608. Close but not the same. The GM blue had more “pop” I found.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
