0 members (), 73 guests, and 9 robots.
Topics128,077
Posts1,056,033
Members48,433
#1419655 08/06/2021 7:11 PM
I wasn't sure where to ask, but, I had to drill out and replace a couple of window regulator rollers and pins on my 46 Chevy (the picture is a similar make to my new ones). Can anyone recommend a rivet gun to reattach the roller with? (I'm assuming I need something similar to the picture). TIA!
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
AD Addict & Tinkerer
Those rivets are installed by peening the backside over with a ball peen hammer on an anvil. A heavy vice or a big hunk of steel like a piece of railroad track will also work. The tool you are showing is for pop rivets and will not work in this application.
Phil
Project Journals
Stovebolt Gallery Forum
I replaced the roller on my window regulators on my '51 and the replacement rivets were semi-tubular. They take a tool to secure them. You can get them from various sources. You just tap them with a hammer. Here's a picture.
Sir Searchalot
Sir Searchalot
Mom, as the guys have said, the "pin" is basically a rivet. (a shoulder rivet). You don't need anything else......so.........This is a good method. Click
Much more control with a vise than a hammer.
@Phak - Thank you! The tool came up in a search and it looked like it would fit the divot on the pin.
@ klhansen - Thank you! Mine aren't long pins like that. They're like the black ones in my picture. Yours look like the pin we're replacing in the shaft of my differential. =)
@ bartamos - Thank you! I've saved the video, and I'll give that method a try.
1946 Chevy
My mistake, I forgot that those were solid rivets that were staked with a chisel. But after watching the video bartamos posted, it all came back to me. wink Just two whacks with a hammer and chisel does the trick. I didn't worry about crunching it in a vice. A correctly sharpened cold chisel expands the rivet nicely. Make sure the rivet is seated all the way in before staking.
Sir Searchalot
Sir Searchalot
Just to straighten out a few things in this thread.
1. The picture that Kevin posted are tools to use for upsetting certain rivets. They are not rivets.
2. The black pins that Mom shows are a hybrid "axle" for the rollers. Part axle, part rivet. The rivet part is a tubular rivet.
I also noticed that Classic Parts list them as starting in 47. Not sure why 46 was not included. So be aware of possible fit/design/application/installation issues.
You don't want to have to order a whole 'nother roller set because you didn't have one seated.
Don't ask me how I know...
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Moderated by  ndkid275, Phak1
