7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible),
56
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2021 Posts: 98 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 98 | Has anyone installed front and rear sway bars on their 55 to 59 1/2 ton pick up. | | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | Both. I used a rear anti-roll bar from a 99 Accord, about 5/8 diameter, and it fits well. Mounted it on top of the frame just forward of the axle area and fabricated brackets to connect to the axle at the spring U-bolts area. The front bar is 7/8 diameter and came with the front sub-frame I used. The truck is very stable.
Mark | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | I have a front sway bar in my '56 3100 pickup, it can out of a '56 Chevy panel truck (they came stock in them). I think it helps a lot with body roll... Mike B  | | | | | Joined: Feb 2021 Posts: 98 'Bolter | | 'Bolter Joined: Feb 2021 Posts: 98 | Can you guys show some pictures. Would like to see the mounting points. Thanks. | | |
