| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Have an 82 c-10, replaced leaking rear wheel cylinders and shoes, and hose. Refilled master cylinder and while trying to bleed system, found I can not open bleeder valve on either front caliper. Don't want to put penetrating oil on bleeder valves as it may contaminate brake fluid. Would a little heat be ok? Or should I just replace the calipers?
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | Never a bad idea to replace the calipers, Tommy. Odd that they won't break loose, though. Usually those are not over-tightened. I wouldn't worry about penetrating oil contaminating the brake fluid, though. You should only get a tiny bit (if any) in there if you just apply it around the threads. Something like liquid wrench or kroil might help.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Heat the bleeder screws with a Propane torch and touch a candle to the bleeder while it's hot. The paraffin will do a good job of loosening the thread, and it won't make it past the tapered seat of the screw to contaminate the fluid. Also, use a 6-point deep socket and a ratchet on the bleeder screw instead of a wrench. Jerry
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Any possibility they are left hand threads? Just a thought.
Ed
| | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | Any possibility they are left hand threads? Just a thought. Not a chance.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2014 Posts: 4,480 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,480 | Just remember brake fluid is flammable if you use a torch...don't want any accidents.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There used to be a repair kit to fix it when it breaks off in the caliper. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Calipers at Rock Auto: $15.32 right or left.
Evan
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Ok, I got the bleeder valves open, just needed a little more pressure. Now the next issue, the Brake light on dash will not go out. How do I get the valve/ switch in the combination valve to center itself, so the light goes out? I don't remember having problems like this years ago when bleeding brakes. Any help would sure be appreciated.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tommy, the shaft which activates the brake warning light inside the combination valve has shuttled over because of a difference in pressure between the two separate braking circuits. Some combination valves have electrical connections which can be unscrewed, if you have good access you could see if your connection will unscrew, if it will unscrew it and look down inside the switch, you should be able to look down inside and see where the shaft has moved one way or the other, the shaft has a low area on it which should be in the center of the switch port. I have had some success putting a small shaft down the hole, applying moderate down force and dragging the shaft back to its centered position. I hope that works for you, good luck. There are tools available that can be put in place before you bleed the brakes which hold the shaft centered while you bleed the brakes. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | As 3B noted, you can remove the connection by unscrewing it and using a pick, small screwdriver, nail, etc; reach into the valve and recenter the plunger. Not too hard of a process. Good luck.
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Opening bleeders one at a time on alternate ends of the system and gently applying the brake will also center the switch. Just use short, gentle strokes on the pedal. It doesn't take much force to move the shuttle valve back and forth. Jerry
