2 members (FAST55, FishinToms53), 91 guests, and 2 robots.
Topics128,115
Posts1,056,632
Members48,450
#1419470 08/05/2021 1:17 AM
Hey guys! Just recently my truck started having starting issues. In the past I could let it sit for a month and it would turn over 2-3 seconds and fire up. Now if it sits for one week I’ll have to dump some gas in the carb to get it running. If I start it everyday it does just fine. Hits almost immediately. It feels like the gas is draining down and no matter how much I pump it or turn it over it won’t pull gas. Will a failing fuel pump cause it to leak off?
Check valve in the fuel pump is stuck open...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks mike. Just as easy to replace it I’d assume?
Since most stovebolt fuel pumps are made in some third world sweatshop these days, finding one that's not bad "out of the box" or fails quickly can be a challenge.
Also check for air leak on suction side of pump. At cranking speeds it might have issues drawing gas. Once running at 450 rpm or higher it will draw gas OK.
I can understand the frustration, I have worked on the Model B for many years. I can barely get my own to run anymore, my advice in this day and time is DO NOT let go of one that has been running good. Warpage both inside and out and what Jerry just commented on. Too many gorillas and third world countries (parts and people), are working on them. Keep what you have and check Mike's Carburator for parts and you tube that he has out there. Check valve is where I would check first. I have an on/off valve on my 54 AD and it comes in handy due to it not being started frequently enough. Look around and find a good used carb, the longer it has set the better for you. I do have 5 rebuilt ones but I would not trust their being better than what you already have. This site has all kind of help for your problem, Jerry, Carbking and many more of our friends have touched the subject over the years. Good luck. Oh I do have some NOS horn and bases for most of the B's. Doc.
