2 members (ChevyBlue, Otto Skorzeny), 224 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
#1419315 08/03/2021 10:41 PM
Hi all, working on my 38 1-1/2 ton and was looking at my tie rod. It seems bent. Is it supposed to be bent or should it be straight ? Thank Smoke[img]http://[/img]
Big Bolt Forum Moderator
I am not familiar with that year but, I believe it should be straight.
Mike
Crusing in the Passing Lane
Tow ‘friends’ are known to be careless about hooking up for a tow, thus lots of bent tie rods, always bent forward indicating tow situation. Take it out find a friend to help hold it, use a press to straighten carefully.
Ed
Thanks Ed, I’ll give that a shot.
Smokeman They all should be good and straight,once freed-up should turn easily with a pipe wrench to set toe-in.
Thanks fixite7 been checking all the vendors for a new replacement. Plentiful for the 1/2 up to 1 tons. Not having much luck for my 1-1/2. Mine is 44-1/4 long,1” diameter . Worst case I can straighten it but for safety, I would rather put on a new one.
doubtful you will find a new one, (unless you happen upon a NOS one on the auction site). I would straighten it and run it while looking for another one.
Mike
back yard wrench turner
Smokeman, I found a couple salvage yards in Minnesota that have our trucks in their inventory. They both would probably have parts available.
http://www.windyhillautoparts.com/contact.html (800) 398-0566
https://www.frenchlakeautoparts.com/ 320-274-8497
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
RPM Motor Sports at 1316 Eberhardt St, Albert Lea, MN 56007 advertises on eBay quite a bit for early truck parts. They also might have something for a '38.
Thank you sir, I will give them a call
Thanks Wayne I will check them out
Shade tree straightening method...
Take the tie rod off, find your closest hardwood telephone pole (don't use a live tree, they don't work as well), grab the long straight end like a baseball bat wrapped in a rag , swing hard and hit the pole right on the high spot of the bend. The tie rod will work itself back to it's original shape due to metal memory. It may take a few swings and you need to adjust how hard you hit as you get it closer to perfect. It's worked for me many times.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
